Exhaust is spitting fuel
Old 08-07-2010, 05:44 PM
Supergibbs's Avatar
Unhappy Exhaust is spitting fuel
I recently removed and cleaned my carbs. Now that it's back together, it only runs for a short while before dying due 2 of the carbs flooding (the two on the fuel pump side). I reopened up the carbs and checked the floats they didn't seem stuck open. Spark plugs fouled up? Spark plug wires? When it runs initially, it sounds OK so I don't think its the plugs, but I'll pull them out to check. What else could it be?
Thanks!
Jesse
Old 08-09-2010, 01:01 AM
Billistic's Avatar
Are the float heights set properly? That can be a cause for carb flooding.
Old 08-09-2010, 07:28 AM
I had the same problem and it ended up being my fuel inlet floats. They kept getting stuck open causing the carbs to overflow.
dagreatbadfinger
09-24-2013 04:45 AM
marty095
03-21-2009 10:32 AM
tank_900rr
07-13-2007 10:36 PM
kash2776
09-03-2005 12:45 AM
Quick Reply: Exhaust is spitting fuel
