exhaust hanger for F1
hmmm....
if you are using the stock end can, i don't think it a good idea to just leave it to hang given how heavy it is. you'd be better off trying to find a hanger/band clamp from an aftermarket unit rather than grinding down the stock unit. or just find yourself a strip of metal to use between the end can and subframe. or get an aluminum or steeltube, bang flat the ends, drill a hole on each end (one to subframe mount and one to muffler mount), bend to shape, and should be it.
you have a D&D so there should be an adjustable steel band? if so, you can get yourself a pair of F4 pegs, they will bolt up and have a mount. they also dont have the back part the rear signals attach to.
oh lord, look at what i found! a little pricey but its what you are looking for.
http://tinyurl.com/2jnak6
I just bid on it when i get it ill put the pics with my others if i can figure out how, it says the file is to big when i try to post them even if i do just one.
