exhaust hanger for F1
does any[8D]ne make a hanger cause I have to remove the brackets for my new tail, or do I have to just cut it off and grind it down.
RE: exhaust hanger for F1
hmmm....
if you are using the stock end can, i don't think it a good idea to just leave it to hang given how heavy it is. you'd be better off trying to find a hanger/band clamp from an aftermarket unit rather than grinding down the stock unit. or just find yourself a strip of metal to use between the end can and subframe. or get an aluminum or steeltube, bang flat the ends, drill a hole on each end (one to subframe mount and one to muffler mount), bend to shape, and should be it. |
i am using a D&D slip-on
I made one for mine using two pieces of 1/8" x 3/4" steel, each piece about 13" long. I can post some pics this weekend if you'd like. I bought the stuff at Ace Hardware for less than $10.
you have a D&D so there should be an adjustable steel band? if so, you can get yourself a pair of F4 pegs, they will bolt up and have a mount. they also dont have the back part the rear signals attach to.
http://www.cbrextreme.com/userpix/2_exhaust3_1.jpg |
oh lord, look at what i found! a little pricey but its what you are looking for.
http://tinyurl.com/2jnak6 http://i12.ebayimg.com/01/i/07/12/af/33_1_b.JPG |
I just bid on it when i get it ill put the pics with my others if i can figure out how, it says the file is to big when i try to post them even if i do just one.
Thats freaking cool man. Hey rrasco, do you know if the new rr passenger pegs will fit?
ORIGINAL: drakito Thats freaking cool man. Hey rrasco, do you know if the new rr passenger pegs will fit? |
Cool. I'll just get some f4 pegs then.
