Endless chain VS. Master Link
Old Aug 14, 2009 | 10:06 PM
ncsponger's Avatar
Default Endless chain VS. Master Link
Hi, I just bought a 1990 cbr600f. It's my first motorcycle and needs some work. It didn't come with a chain so I am in the process of finding one.
My Clymer repair manual says "do not install a master link drive chain, use only an endless chain", for strength and reliability reasons. My problem is I am having a hard time locating an endless chain. I believe the size is 530-110.
Does anyone have any ideas on where to find the correct chain, or is it sufficient to use a chain with a masterlink. Thanks for any help.
Old Aug 14, 2009 | 10:30 PM
Restlesswildman's Avatar
I think what they are trying to say is not to use a standard clip style master link.
My take on an endless chain is that it still has a master link, but it is swedge or translated into USE a special tool to spread the ends of the masterlink pins to lock the side plate on.
I believe that a RK530 chain is what you need. Make sure to replace the sprockets also when you do the chain. Get a can of chain wax also!
Old Aug 15, 2009 | 12:41 AM
PlayfulGod's Avatar
is referring to a rivet type master link verses a clip style. Clip style master links are not intended for street bikes and are bad news!!!
Old Aug 15, 2009 | 02:51 PM
thrasher572's Avatar
^ as above. The tool is not that expensive and is also used for removing the old chain(for the next one) as well. I would recommend the rivet style as I have lost the clip more than once.
Old Aug 15, 2009 | 08:46 PM
ncsponger's Avatar
Default Thanks
I appreciate the info. That cleared things up!
Old Aug 15, 2009 | 09:54 PM
Dissevered's Avatar
I've been using a clip for 7 years now and haven't had a problem. *shrug*
Speaking of a cheap chain tool... I have only seen them for 80+ dollars... that is expensive to me. Have you guys found them anywhere cheaper?
Old Aug 15, 2009 | 11:58 PM
deadsp0t's Avatar
i too have clip type on a 600cc, wasnt aware when i ordered it but the the website said good for upto 7500cc or 130hp. no 1000cc bikes @ all.
iam told i can go to the shop and get a rivet style installed though?
Old Aug 16, 2009 | 07:16 AM
PlayfulGod's Avatar
its your leg guys
Yes a shop will install a chain for you. Catch is it has to be on the bike And any reputable shop will always use a rivet type master link
Old Aug 16, 2009 | 11:38 AM
My bike pitched the clips so often I carried a spare at all times...never had an issue with the riveted style.
Old Aug 16, 2009 | 01:09 PM
Incognito's Avatar
Official CBRF Welcome Crew Undercover Agent
You can buy the "Pit Posse" tool on eBay ($40). Also, I just found out Harbor Freight carries a chain breaker that can be converted to a riveter ($9); here's a video on that one: LINK.
