dead hurricane
Old Dec 16, 2007 | 06:51 PM
trav9980's Avatar
Default dead hurricane
i just bought a hurricane not runing maybe someone can help so this is what is up the motor was rebuilt and the guy did not know what he was doing the timing was off the plug wires were in the wrong place. but i fixed that and set the valve clerence it only starts when you spray gas in the carbs so i cleaned them and and made sure the pump was working and it does so i am going crazy with this thang so please help
Old Dec 16, 2007 | 10:49 PM
michigan_313's Avatar
Default RE: dead hurricane
okay, it starts when you manually add gas. fuel pump is working.
now, are the carbs actually delivering fuel? pump may work but is it pumping fuel to carbs? are the carbs getting fuel in the float bowl? are there any foreign obstructions in the carbs' fuel circuit, ie. clogged jets?
Old Dec 17, 2007 | 07:59 AM
trav9980's Avatar
the fuel pump pumps until the bowls fill up and then the pump stops is that normal? i cleaned all the jetsthey wereclean the guy i got the bike from cleaned the carbs two times before i got the bike the plugs are new so there not fouled i did take off the fuel line that goes to the carbs and put my finger over it not much presure thin the pump stoped its like its not geting fuel i am wondering if maybe there is not enough compreson
Old Dec 17, 2007 | 11:46 AM
ORIGINAL: trav9980
pump should always be pumping if bike is running. does it pump a lot or a little fuel? you could always bypass the pump as a test to see if carbs will take fuel directly from tank.
Old Dec 17, 2007 | 01:25 PM
trav9980's Avatar
i tried to bypass the pump nothing i am cheaking compresson how much psi? in the maual it says (185 +28 is that 28 psi or 185 psi
Old Dec 17, 2007 | 01:51 PM
trav9980's Avatar
i just found out the bad news no compresson that sux i paid 900 for the bike what a waste
Old Dec 17, 2007 | 06:43 PM
no cylinder compression? on a rebuilt motor? what was rebuilt then? it's not a complete waste. think of it as a long term project.
Old Dec 17, 2007 | 06:45 PM
bergs's Avatar
ORIGINAL: michigan_313
See post #1:
...the motor was rebuilt and the guy did not know what he was doing...
Old Dec 17, 2007 | 07:43 PM
tds94probe's Avatar
probably left the rings out so the pistons would slide in easier..... Just tear er apart and find out the problem.
Old Dec 17, 2007 | 10:19 PM
probably forgot to install the piston return springs, too.
