dead hurricane
dead hurricane
i just bought a hurricane not runing maybe someone can help so this is what is up the motor was rebuilt and the guy did not know what he was doing the timing was off the plug wires were in the wrong place. but i fixed that and set the valve clerence it only starts when you spray gas in the carbs so i cleaned them and and made sure the pump was working and it does so i am going crazy with this thang so please help
RE: dead hurricane
okay, it starts when you manually add gas. fuel pump is working.
now, are the carbs actually delivering fuel? pump may work but is it pumping fuel to carbs? are the carbs getting fuel in the float bowl? are there any foreign obstructions in the carbs' fuel circuit, ie. clogged jets?
RE: dead hurricane
the fuel pump pumps until the bowls fill up and then the pump stops is that normal? i cleaned all the jetsthey wereclean the guy i got the bike from cleaned the carbs two times before i got the bike the plugs are new so there not fouled i did take off the fuel line that goes to the carbs and put my finger over it not much presure thin the pump stoped its like its not geting fuel i am wondering if maybe there is not enough compreson
RE: dead hurricane
ORIGINAL: trav9980
