Cutting fender/exhasut removal help
Old 03-23-2009, 02:15 PM
Micscience's Avatar
Default Cutting fender/exhasut removal help
What would be the best tool to recut/shape my front fender? Also I want to remove my headers/manifold from the bike to paint them. If I do so can I just put them back on or am I gonna need a gasket?
Attached Thumbnails Cutting fender/exhasut removal help-mayas-pictures-002.jpg
Old 03-23-2009, 02:44 PM
lloydiecbr's Avatar
hello . i just used a dremel with a cutting disc and a sanding wheel to do mine . you will only need to change them if they are broken or missing . but use some sealent to be sure . hope i have helped
Old 03-23-2009, 04:14 PM
hypeshipe's Avatar
a jig or some kind of reciprocating saw would be my choice
Old 03-23-2009, 05:16 PM
Micscience's Avatar
Sorry but I don't quite follow what you are saying. What do I change? what can brake? and sealant for what?
Old 03-23-2009, 05:46 PM
hypeshipe's Avatar
I think he's saying to change (replace) the old gaskets if they break when taking the old exhaust off. You can use a liquid gasket from the hardware store (sealant) instead if you wish
Old 03-23-2009, 06:42 PM
tripicana's Avatar
use a thin coating if any sealant. try not to remove the gaskets from the head, keep them in the same spot.
Old 03-24-2009, 12:18 PM
Micscience's Avatar
ahhh, I see...!
alright thanks fellas getting on that as we speak.
Old 03-26-2009, 12:17 PM
Micscience's Avatar
I broke an exhaust bolt what should I do?
Attached Thumbnails Cutting fender/exhasut removal help-mayas-pictures-014.jpg
Old 03-26-2009, 01:36 PM
michigan_313's Avatar
should be able to go to local hardware store and pick up a new one. auto supply store might even have that size.
Old 03-26-2009, 07:14 PM
Micscience's Avatar
yeah but the bolt is in bedded into the engine I believe
Quick Reply: Cutting fender/exhasut removal help
