Cbr600f carb disassembly question
As you can see I've had to do a bit of welding because the bit that holds the float pin in broke off.
Im trying to get ready to drill through it but the brass part where the float needle sits is in the way.
My question is: can that part be removed from the carb? And if so how would I do that? Thanks so much
It just doesn't look like it's high enough to interfere with where/how that float pivot pin goes through.
Based on the image, I was thinking that it didn't have a hole in it at all anymore. The thin brass tube near the top of the image prevents the pin from being removed out in that direction. So the bottom riser has to be the side it's removed from. It just doesn't look like it has a hole anymore. Given that the pin goes from one side to the other, I don't see how the float needle seat can be in the way. A drill bit would be the exact same diameter as the pin. I guess we'll wait for @3bikes1will to respond.
