Carb fastener info. prepare to reduce
Old Sep 22, 2011 | 02:41 AM
redmason89's Avatar
Default Carb fastener info. prepare to reduce
always wondered why no one had posted the sizes to the bolts on the carbs since the originals love to strip.
each carb has a total of 12 fasteners heres the break down :
4 for the float bowl
4 for the diaphram cover
2 for the cut off valve cover located on the side of the carb
and 2 for the bracket that holds them all together
you could also replace the screws on choke bar arms theres a total of
3 screws here (pic shows two)
the carbs only use two sizes they are M4 0.7 and M5 0.8
4x float bowl covers M4 X 14mm
4x diaphragm cover M4 X 10mm
2x Cut off valve cover M4 X 8mm
2x Bracket bolts M5 X 10mm
(to do all carbs multiply by 4)
optional
3x choke arm thingy bolts M4 X 6mm
hope this helps somebody out
-redmason
Old Sep 22, 2011 | 03:11 AM
Boxdgm's Avatar
Nice to see someone else switching out those crappy phillips bolts. I did this on mine after having to remove all the old stripped ones with a damaged faster extractor.
I had to hit 4 different hardware stores to find all the ones i needed since they only had a few sets of each. Dont forget about the 8 that hold the airbox tray on. I think they were m6.
redmason89
Sep 22, 2011 12:23 AM
94caprice
Oct 25, 2008 07:56 AM
rider0033
Jul 26, 2008 03:11 PM
ddaren
Apr 15, 2008 07:20 AM
buddyrm
Aug 4, 2006 05:06 PM
