Carb assmbly difficult to go back into boots
![Cool](https://cbrforum.com/forum/images/icons/icon6.gif)
My last post was back in Aug of last year.I successfully put new fuel o-rings in carb fuel rail,with all of your help !
Carb assmbly a little difficult wanting to go back in rubber manifold boots.
I think they are a little stiff/old.Had the carbs off before,but I had a warmer garage to work in-now I'm outside.
Any suggestions?
Maybe some oil or WD-40???
Any suggestions?
I use Armor-All on the boots. A standing coat left on over-night, then polish the
excess (if any) off the next day. That helps soften them. Put the boots on the carbs
and tighten down, then put the entire assembly on the bike, at once. I also wipe some
more Armor-All on the inside of the boots as a lube to ease them on the bike.
Ern
Ern
Ern
Ern
I massaged the boots a little,then rocked/pushed one side,then the other,keeping an Eagle-eye-visual to keep things even.Then,whamo-carb assmbly went in !!!
I had the same problem, and after pulling the carbs a few times it gets really annoying. Not to mention mine were so bad I thought I was going to break something.
There is a guy on Ebay called Georgefix that sells new replacements for $40 a set. They look just like the oem ones I took off, and slip on like butter!
