Bolt size?
Old Feb 18, 2007 | 10:31 PM
CanuckDave's Avatar
Default Bolt size?
Does anybody know offhand what size this bolt on the stator cover is? Neither a 10mm or 8mm fit, so I'm not sure what size I need to go out and buy.
Also, I've got a haynes manual for the bike, but I can't seem to find anything on the stator cover, anything special I need to do when I'm replacing it? (cracked when I lowsided a few months ago, gota replacementoff ebay)
thanks in advance
Old Feb 18, 2007 | 10:57 PM
michigan_313's Avatar
Default RE: Bolt size?
that is a crankshaft hole cap. it is a 10mm allen. they are on pretty tight.
Old Feb 18, 2007 | 10:59 PM
drakito's Avatar
That bolt is for the crank access when setting your valve timing, try a 9mm. The bolt above the "A" in honda is for the timing marks.
The case comes right off no hidden bolts, leave the motor in the frame, this will also access the clutch. The only tricky part on removal is the clutch cable. Reinstall the same way, just use locktite on the bolt directly above the crank access cover(or on all the bolts, thats just me). Torque to 11 ft-lb, 1/4 turn, twice. No set way in which to tighten just remeber to do the star pattern(directly across from each other and snug tite at first, till all bolts are snugged.) Good luck.
CP49
Jun 14, 2013 07:55 AM
Goats
Jan 12, 2011 10:45 PM
nykuryu
F2 Tech
Apr 3, 2010 02:18 PM
Chunga
Sep 28, 2009 04:54 AM
bassJAM
Nov 5, 2007 01:31 PM
