Bog at idle and around 5k
Old 05-12-2012, 08:22 PM
reddoctor's Avatar
I found out it was the slow jet. I pushed speaker wire through it and it cleaned out. I used speaker wire on other parts after hearing people cleaning out passages with guitar string. I just didn't know how small the passage was.
It still won't go over 8k unless you just rev it in neutral.
The rpms hop a little while maintaining the throttle.
Old 05-12-2012, 08:40 PM
TahoeRider's Avatar
I always clean the jets and small passages with compressed air after using carb cleaner on them. The wire trick works too, but you just have to be careful because you can damage the jets with any hard object like a piece of wire. Glad to hear you figured it out.
I hate to say this, but you might have to take the carbs apart one more time and blow everything out and make sure there are not any more blockages somewhere. Make sure to sync the carbs as well and see how she runs after that..
Old 05-13-2012, 10:13 AM
reddoctor's Avatar
Okay i'll do thats. Thanks for the help!
SPR-GRN
05-07-2012 06:08 PM
prowheelie92
08-05-2010 04:42 PM
acquarossa
06-09-2010 07:05 AM
ThisisMickey
02-10-2007 06:22 AM
BRC223
05-29-2006 05:22 PM
Quick Reply: Bog at idle and around 5k
