bad running
Old Sep 18, 2008 | 01:25 PM
lloydiecbr's Avatar
Default bad running
hi all can anyone help me please . my 1990 cbr 600 fl keeps bogging down at high revs . its fine going around town but as soon as i get on the open road and open it up it dont want to know . i hav cleaned the cars out changed the filters and plugs with no joy . please help .thanks
Old Sep 18, 2008 | 01:42 PM
michigan_313's Avatar
Default RE: bad running
what exactly did you do when you cleaned the carbs? did you just hose it down with cleaner or take them apart?
bogging at high revs sounds like floats or needle problem.
Old Sep 18, 2008 | 03:37 PM
Hurricane rider's Avatar
or a synchronization issue.
Old Sep 18, 2008 | 05:09 PM
thrasher572's Avatar
or starving for fuel... Check your fuel filter, and pump output.
Old Sep 19, 2008 | 01:27 AM
lloydiecbr's Avatar
thanks for your reply . i replaced the fuel filter when i cleaned the carbs . how would i check the out put of yhe pump . the pump ticks and pumps fuel at low revs ie tick over . is that normal ?
Old Sep 19, 2008 | 01:29 AM
lloydiecbr's Avatar
thanks for your reply . im a bit thick what do you mean sink.
Old Sep 19, 2008 | 01:33 AM
lloydiecbr's Avatar
thank you for your reply . i stripped the the carbs as best i could without getting mixed up . but i did manage to get them clean ie the floots jets and needles and breathers . and still at a loss .
Old Sep 19, 2008 | 05:42 AM
by synching them, I mean basically balancing the air flow to each cylinder. do a search on carburetor synch, you'll get the idea. I've done every single carb rack I've owned, some more than once.
Old Sep 19, 2008 | 06:47 AM
lloydiecbr's Avatar
thanks ill give it a try
Old Sep 19, 2008 | 06:56 AM
no problem, a good carb synch never hurt anything.
