any ideas why my speedo just stopped workin?
Old Oct 17, 2006 | 01:50 PM
rrasco's Avatar
Default RE: exhaust
cool...that can is hot!
Old Oct 17, 2006 | 08:27 PM
Karl's Avatar
Default RE: exhaust
thanks . my bike likes to cut out every once in a while whilst i'm driving and i have to let it sit for about 5 minutes before it'll start again, well.... it sort of slows down and chugs to a hault. its happened twice since i've had it. do you know what might be causing it and how i can solve this problem?
Old Oct 18, 2006 | 01:45 AM
zerochickenstrips's Avatar
Default RE: any ideas why my speedo just stopped workin?
I'm thinking your speedometer cable internal has snapped. Happened to my F2. Unhooked the cable from the speedo gear on the front axle and the cable (1/2 of it) just slipped out. I'd check this.
Old Oct 20, 2006 | 11:39 AM
Karl's Avatar
i took the center out of my speedo cable and it seems to be in 1 piece but now there is a squeeking at the front wheel, do u think i may just need to change the whole speedo fitting on my front wheel? i have found 1 on ebay for £10 so i may as well give it a go.
Old Oct 20, 2006 | 05:23 PM
michigan_313's Avatar
i think it would be worth a try to change out that gear unit on the front axle. it's very rare that the needle on the instrument cluster will go out unless it has been damaged in an accident and seeing as how your cable is okay, then you've pretty much looked at everything related.
Old Oct 24, 2006 | 09:16 PM
Karl's Avatar
hey rrasco have you managed to put mesh in your maintenance pannels? hows that goin? did you solve the problem with clearance from the frame? would love to see pics wen its done
Old Oct 25, 2006 | 12:48 PM
rrasco's Avatar
ORIGINAL: Karl
no not yet. i have wanted to do it for months now. it will come later, i still have my tail swap to finish as well as some other projects first. the bike is also getting painted before i put it on.
Old Oct 26, 2006 | 11:11 AM
HondaKidF1's Avatar
Can anyone answer the question about the bike cutting off? Mine did this a few days ago and I was lucky that the light stayed red long enough to restart it. If anyone knows what the problem is can they explain how to fix it please. BTW nice looking bike.
Old Oct 26, 2006 | 01:02 PM
rrasco's Avatar
sorry, i have no idea.
Old Oct 26, 2006 | 04:36 PM
ORIGINAL: HondaKidF1
start this question in another thread and i'll ask you some questions to see if i can help you narrow it down.
