Adjusting Idle 89 CBR 600F??
My 89 CBR 600F when driving boggs alot. Can give it full throtle with out bogging or hestating. The choke is at half way in order for it to keep running when it is warm. If I close the choke all the way off then the bike dies. If the Choke is all the way open then the bike idles at about 2000 or 3000 RPM. Is there away to adjust the idle so that when the choke is off it idles right instead of dieing? How do I do that? Where is it located? I would look in a manual but I had to order one and wont get it untill next week.
RE: Adjusting Idle 89 CBR 600F??
if you take off the left side maintenance panel, angle yourself from the front of your bike and look towards the back of the bike inside the panel and there will be a black ****, thats the idle adjustment. be careful as a little turn can do alot of changing. i dont have the pic with me, but i will post it when i go to work on monday (its on that pc).
Adjusting the idle is a lot easier than sycing the carbs, so I might try playing with the idle adjust first. It's actually really hard to get to just from the maintenance door. I had to take my whole left fairing off to get to it comfortably. try looking back in under the fairing and see if you can spot it, but if not taking the whole thing of make sit a lot easier to find.
