8k flat spot
i misspoke. alternators are the same but the pulse generator is different. also, the cdi is different between pre and post '88 models. could it be that your wiring harness is from a different year from the engine? if the engine is a 90 then somehow it must be running a 87/88 wiring harness. you should really look at the wiring schematic and check it against the wiring harness and especially the cdi. if it all looks kosher then there is a slight possiblity that it is related to another part of the electrical system that is not as obvious. i won't get ahead of myself until you say otherwise on the cdi.
Thanks for starting up the thread lloydie.. and for all of the replies so far..
Wealth of knowledge on here![Icon Bike](https://cbrforum.com/forum/images/smilies/icon_bike.gif)
It appears that the CDI's are different..
I have ordered a new CDI for a 1991 fl which should be the same. Its also coming with the full wiring loom..
Could the CDI have been causing this problem?
Will have a look over the loom this evening to firm up which year bike its from..
Cheers peeps..
Cheers peeps..
The wiring loom in the manual for the 600's seem to be the same no matter what year..
I think the loom may be form a 1000...
So hopefully with the new loom and cdi will help..
Loom should be with me on thursday so can fit it then and let you know..
I don't think the issue is to do with the airbox as I have tried lots of configurations.
