88' CBR 600 Starter Issues
Hey guys, first post here. I recently bought an 88' cbr 600 of craigslist as a project bike. I have been trying to figure out whats going on with this starter, and was hoping to get some help. So when I turn the bike on and press the starter and the solenoid clicks, (so the switch inside is working, I assume). So I then check the starter motor, when I pull it off and hook it up to a 12v battery it scared the **** out of me as it spun to life in my hand. (So the starter motor works?) I then hook up the starter motor back to its wiring on the bike but leave it not attached to the motor, and when I press the starter switch the motor spins! So I put the starter back on the bike, attached to the engine and press the starter and once again the solenoid just clicks when I press start.... I have never seen this happen before... What the hell is going on??
The battery is brand new, they tested it at the shop and its got plenty of juice. I dont have a stand but I tried turning the wheel with my hands and couldn't get it to move, I cant bump start it at the moment, the clutch doesn't work %100. But I have another clue for you guys and its kind of odd, when you press the starter button the solenoid clicks regardless if the kill switch is on Off or On. I found that odd, maybe the previous owners disabled it? ( I wont be able to try and bump start yet but in the meantime do you think I should put a few drops of oils down each cylinder so it can try to loosen them up?
