87 Hurricane build
Old May 12, 2008 | 01:00 AM
tripicana's Avatar
Default 87 Hurricane build
hello all,
Ive finaly dedicated my time and resources to the reconstruction of my 1987 CBR600 Hurricane. The project began almost a year ago as a mostly complete, backet case bike. I went through it, got the engine running, and its been taking up space in the garage since. I completely stripped it down, and will swap everything over to a titled frame.
I all ready have alot of questions, and i will try to keep them in this post.
I was thinking of media blasting my rims, will the bare aluminum be a problem?
unfinished spokes with a polished lip, will it need to get clearcoated?
here she is, awaiting assembly
Old May 12, 2008 | 06:57 AM
cbreric's Avatar
Default RE: 87 Hurricane build
zoop seal work good on bare aluminum I thought, kinda whats its intended for. is that a cb1 next to the hurricane, or a hawk? looks like a project all right
Old May 12, 2008 | 02:10 PM
michigan_313's Avatar
at least you don't have that infamous crack in the frame.
Old May 12, 2008 | 03:21 PM
tripicana's Avatar
cbreric - the bike is a 96 CB750 Nighthawk
the frame does have the crack, it will get welded this week.
Old May 12, 2008 | 07:10 PM
cbreric's Avatar
nice bikes then good luck with the weld!
Old Aug 6, 2008 | 12:19 PM
tripicana's Avatar
could someone measure the distance between the ground and bottom of the oil sump, with the bike straight up? i'm going to build a stand to lift the bike high enough to have the wheels just off the ground. i got sidetracked, but did get new tires, powdercoated the rims, polished the forks, and found the missing parts it needs.
ill post pics once i get a rolling bike.
Old Aug 11, 2008 | 05:55 PM
tripicana's Avatar
Default RE: 87 Hurricane build (brake shims)
i am missing the front brake rotor dampening shims, will fiber washers from the hardware store be fine?
Old Aug 15, 2008 | 12:34 AM
Billistic's Avatar
I think so, I've read of others doing so. The washers are pretty thin ( almost useless IMO ) but they put them there for some reason. I put a set of good used rotors on recently and reused the old washers with no problems
Old Aug 15, 2008 | 03:54 PM
tripicana's Avatar
cool, i went ahead and ordered some oem shims. i figured they were pretty thin and couldn't really find anything localy.
Old Aug 15, 2008 | 04:40 PM
rrasco's Avatar
aghhhh! you paid for those damn things? My dad found some at some store, he bought a handful of them for $1. I wasn't paying OEM prices for them.
