-   CBR 600F (https://cbrforum.com/forum/cbr-600f-15/)
-   -   87 Hurricane build (https://cbrforum.com/forum/cbr-600f-15/87-hurricane-build-143826/)
ben12178 Dec 24, 2012 11:13 PM
87 Hurricane build
Hi all I stopped by to share my build with you.
My name is Ben and the progress of my cane.
I bought it 3 years ago with no plastics and started building it almost at once.
This is the day I brought it home
http://i88.photobucket.com/albums/k1...0922091817.jpg
I started buying parts and modifying until I came up with this
http://i88.photobucket.com/albums/k1...o/IMAG0033.jpg
I rode it like that for a season and the last ride of the season a bolt for the rocker arm retainer came loose and went for a ride with the cam chain.
So I pulled the engine and tore it down for an overhaul. I figured while the engine was out I would make a few changes. During that time my daughter was born and my bike went on the back burner until recently. I stripped and painted the frame.
Then I put the overhauled engine back in and all the goodies I had collected and spent considerable time modifying to fit.
http://i88.photobucket.com/albums/k1...2-09202950.jpg
http://i88.photobucket.com/albums/k1...2-10204925.jpg
I still have some bodywork to do before I can paint but its all primed
http://i88.photobucket.com/albums/k1...ps7537da79.jpg
Thats where it is right now having a 18 month old cuts into my do work time but its getting close. I'll update as I get more done
gotcbr Dec 24, 2012 11:33 PM
Welcome to CBRF Ben.
We like rebuild/mod threads. Thanks for sharing.
Keep us updated.
dodger79 Dec 25, 2012 03:50 PM
Hi Ben you're doing really well! I'm in a similar position as I've a 3 1/2 yr old girl and an 18mnth old boy and know about how it limits workshop time a fair bit. The kids definitely are priority so I try to use the 'little but often' rule for working on my cane. I might spend just an hour 3 or 4 evenings a week during their bedtime but it means that each session is focussed and I make small but definite progress so I enjoy doing it and keep motivated. I love the new swing arm and subframe - what are they off? What are you hoping to do next? Do a vid and show us round the old girl man!
Anyway stick at it, bikes make dads happy and kids need happy dads is what I reckon so messing with bikes is important :)
Zachy72 Dec 25, 2012 04:29 PM
What kind of front fender is that? i'm not a fan of the stock one
ben12178 Dec 25, 2012 07:15 PM
Yeah I usually do an hour or so after she goes to bed and go full tilt when shes visiting her mom. I'll try to get a vid of it but right now its not running I'm still running the wiring.
The swinger, shock and rear wheel are off of a 05 600rr
The subframe and tail are from a 01 GSXR 750
The front fender is the stock one that I spiced up a bit with a coping saw.
I had to narrow the swingarm pivot and I had someone make custom spacer tubes. I also had to make the dogbone mount and weld it on as well as the subframe mounts.
ben12178 Dec 25, 2012 07:19 PM
I'm very busy right now I'm putting 2 of my own bikes back together and getting my friends f2 ready for paint. My other bike is a 89 kwak zx10 that is a decomissioned drag bike. You can see the front wheel poking in a few of the pics. I'll post a pic of where I have it in the build process if its allowed since its not a cbr
ben12178 Jan 11, 2013 09:32 PM
Well after being sick for a while I finally found time to work on the honda. I have all my body pieces ready for paint after several coats of priming and sanding. I lengthened some of the wiring since the battery box sits farther back now and made new battery cables( for a grand total of $13 I might add). I started it up to make sure the rebuild on the engine is good and found a new setback. It seems my carbs sitting for almost 3 years caused some issues cause they are leaking at the fuel tee. So now I have to tear them out and replace the o-rings hopefully the plastic tee isnt cracked. I still have some wiring to run for the lights. once I get it painted and everything squared away I get some finished pics up
ben12178 Jan 16, 2013 11:25 AM
Well I found some time to work on the old cane yesterday.
I made a rear tank mount for it
http://i88.photobucket.com/albums/k1...ps3b1a26e1.jpg
I think I'm going to redo it though so that the bolt goes in from the top cause after looking at it I dont like how it looks like that.
I also started working on ways to mount my acewells speed sensor cause it used to be held to the forks with 3m tape
http://i88.photobucket.com/albums/k1...ps33e558cf.jpg
not sure if this is going to be the final product for that or not.
cbrjoka Jan 16, 2013 01:43 PM
hi mate have you any info of how you did the swingarm swap pics of cuts and measurements etc
ben12178 Jan 16, 2013 06:10 PM
No I didnt take pics when I was doing that part. What I did was Measure my stock swinger at the pivot then marked the rr swinger on the side opposite of where the chain runs and cut it. I had someone make new bushings to fit the hurricane pivot bolt cause I didnt want to drill my frame that big. For the dogbone mounts I cut the center stand bracket out and made 2 mounts out of steel plate and welded them where the centerstand bracket was.
