1990 cbr600 Turn signal wires????
I just got new led turn signals so I can at least look like i ride legal on the streets, my new problem is which color wire from the bike is ground and positive?
I have a orange, a blue, and a green wire for 4 things to plug in to. Any ideas? Or do you know if LED turn signals will work?
The positive is different for each blinker, and the ground is one cable for both the blinkers and the tail light. I believe it's the brown or green one that's the ground - if you look there should be three connection points at the tip under the rubber, while the others each one have one connection point.
