WTF is wrong with my 06 1krr
RE: WTF is wrong with my 06 1krr
[ul][*]To set the "REV" light function press and hold "SEL", then turn the bike on.[ul][*]Release the "SEL" button and press the "RESET" button repeatedly until the needle is at the desired rpm for the shift light to activate. (anywhere from 4k-12k)[*]After desired RPM is chosen, press "SEL" once[*]Repeatedly press "RESET" and choose from the following:[ul][*]Fast flash - high brightness[*]Fast flash - medium brightness[*]Fast flash - low brightness[*]Slow flash - high brightness[*]Slow flash - medium brightness[*]Slow flash - low brightness[*]Solid light - high brightness[*]Solid light - medium brightness[*]Solid light - low brightness[/ul][*]After desired REV function is selected, press "SEL" to finish[/ul][*]To switch KM to MPH or MPH to KM[ul][*]Press and hold "SEL"[*]Then press and hold "RESET" so that you are holding both buttons in. (clock hour will flash)[*]Release both buttons.[*]Press "RESET" repeatedly to adjust hour[*]press "SEL"[*]Press "RESET" repeatedly to adjust minutes[*]press "SEL"[*]Press "RESET" to switch mph / km/h[*]Press "SEL" (If gauges read in KM by default, the process is complete at this point)[*]Press "RESET" to switch temp to read in "F" or "C"[*]Press "SEL" to finish.[/ul][/ul]
