Where is the ram air on the new CBR1000?
Old Sep 27, 2006 | 11:13 PM
nycbr's Avatar
Default Where is the ram air on the new CBR1000?
I have only seen pictures here and in magazines of the 2006 CBR1000. I don't see the ram air on the new models. Where is it?
Thanx
Old Sep 28, 2006 | 12:08 AM
baxsom's Avatar
Default RE: Where is the ram air on the new CBR1000?
look under the triple clamp from the bottom by the horn
the air duct is behind the grill
http://www.rogueracing.org/flap.htm
Old Sep 28, 2006 | 12:44 AM
zerochickenstrips's Avatar
It is directly above the radiator. If you want to see the "flapper" in action, get a rear stand, crank it up, put it in first and look at the grill and give the throttle just a small twist (about 1000 rpms more than ide). You'll see the flapper shut and then open again when you let off the gas.
Old Sep 28, 2006 | 12:45 PM
gassarvet's Avatar
Does the flapper not have any purpose, like kepping water etc out when washing or such?
Old Sep 28, 2006 | 05:50 PM
roxy_33's Avatar
what I understand its only a noise thing. When I pulled mine out I noticed no negative changes at all, just sounded better and got a small performance bump when leaving lights. If you look at your airbox design, you would have to be a complete idiot and concentrate a stream of water into your intake to get water through your filters and into the stacks.
Old Sep 28, 2006 | 11:03 PM
baxsom's Avatar
go to www.1000rr.net
there are many many posts on what the flapper is and what it does and why it is a good idea to remove it
the rogue racing site i posted give a good explanation of what it does
Old Sep 29, 2006 | 05:46 AM
gassarvet's Avatar
Thx m8!
droopd
Mar 29, 2006 11:24 AM
wickedsprint
Mar 22, 2006 06:05 PM
kenny7883
Nov 28, 2005 12:26 AM
