TIRE PSI
Old Nov 15, 2007 | 11:08 AM
CBRJESSIE's Avatar
Default TIRE PSI
What is the recommended PSI that your front and back tire should be at just for normal street driving conditions. I have a 2006 cbr 1000rr with stock tires if that helps any.
Old Nov 15, 2007 | 12:00 PM
07 DblR's Avatar
Default RE: TIRE PSI
i asked my buddy whos got a 1000rr he said he keeps his at 35/39 and rides only street. I imagine it would imagine what type of roads you ride on... we live in florida, so all our roads are flat mostly asphalt...
Old Nov 15, 2007 | 12:53 PM
s.ga.rider's Avatar
36f 42r is recommended max pressure. I run mine at that for commuting.
Old Nov 15, 2007 | 02:06 PM
dizzie56's Avatar
30/30 - 35/35
Old Nov 15, 2007 | 04:37 PM
MgA_ODEN's Avatar
ORIGINAL: s.ga.rider
36f 42r is the recommended 2-up riding pressure.
I run mine 33f 33r solo.
Old Nov 15, 2007 | 04:51 PM
baxsom's Avatar
check this thread. not going to go way too into it but basically
the 36/42 is for a 200+ rider street riding
http://www.1000rr.net/vb/showthread.php?t=40118
Old Nov 15, 2007 | 05:43 PM
s.ga.rider's Avatar
ORIGINAL: baxsom
That would be me. lol
Old Nov 15, 2007 | 07:19 PM
Demon RR's Avatar
dayum, all the above seems like high tire pressures. 32f-34r street on 2ct's with a 55 rear for me.
Old Nov 15, 2007 | 07:39 PM
vjhils's Avatar
Whatever your tire says I've heard to go -2 for the best handling, I'm not the authority on this but it seems to work for me.
Old Nov 15, 2007 | 08:04 PM
baxsom's Avatar
ORIGINAL: vjhils
in theory you need to have your cold tire pressure so that it gains 5psi when the tire gets hot.
that is the supposed optimum tire pressure.
on the street i run 32/36 in the pilot powers on my 1000rr and after a hard ride they are ususally in the neighborhood of 34-38 when i get home. so i need to technically drop them lower to get them hotter but i hate sacrificing mileage and tire wear on a street bike.
on the track i run 30/29 and after some good hot laps 35 +/-1 psi in each tire with a temp of 180 degrees on the thermometer if i get to it as soon as i pull into the paddock
