Tech Question
Has anyone noticed their bike feels bouncy on the front end when steady cruising 75 mph and below all gears? My 06 1000 feels as the more miles I get the more bouncy it feels. I've tryed varying my tire pressures and adjusting the suspension all the way hard and soft and everywere in between, but no real change in ride. I have about 7,000 milesand newer tires(2,000 miles) which were balanced, my bike was never wrecked or really wheelied and my front end seems to be in good shape compresses and rebounds correctly-(forcing it down by hand).How aboutsome input?
I worded that incorrectly I have 7,000 total-2,000 on pilot power 2ct's. When my tires were balanced they installed dyna beads (and then checked the balance)which are suppose to last the life of the tires. http://www.innovativebalancing.com/motorcycle.htm
Try decreasing your rear suspensions preload. It may be too high. If it is, your front end will feel soft and bouncy as the rear wont move with the front.
also, I'm not convinced of those beads. I would re-ballance the wheel with regular weights.
I tried this setup seems better http://www.hooliganbiketech.net under the suspsension setup page
Front Preload
FULL HARD
Front Rebound Damping
1 turn from full stiff
Front Compression Damping
2 turns from full stiff
Rear Preload
6 from full soft
Rear Rebound Damping
Rear Compression Damping
20 click from full stiff
Front Preload
FULL HARD
Rear Preload
6 from full soft
