spark knock under 3000 rpm
RE: spark knock under 3000 rpm
ORIGINAL: SRider
Sup fellas, first time on. I just bought a used 06 1000rrthats supposedly all stock and it looks like it. It'sonly got 2k miles on it but it sounds like itspark knocks under 3k rpm. wondering if anyone else has had this problem. thanks
I'm building a custom ignitiontiming controller,which I hope to get installed and tested within the next week or two. If pulling back the timing eliminates the noise, I'll know beyond a reasonable doubt what is happening inside my engine...
[quote]ORIGINAL: SD2007
why the cutsom job, just get the powercommander and ignition module
ORIGINAL: SRider
ORIGINAL: baxsom
I may end up going that route, but before I shell out $300 for the Power Commander module I want to verify that retarding the timing can stop the detonation without completely killing low end performance or causing excessive exhaust gas temps. If I can't find a satisfactory compromise, I'll just live with the factory timing and save the $$$ I would have wasted on the PC ignition module. For the cost of a few specialty IGBT's and misc. components I can make a test module for less than 1/10th the cost of the PC unit.
