SO PLEASE HELP ME OUT
I have an 07 1000rr with about 4k on her
every now and then it blurps out a lil bit of collant on the fearing from the boil/runout tube i dont know if this is normall or a potential problem just wondering if any1elses 1000s do that
any input will b greatly appriciated
Sounds like maybe just a little too much coolant.
Check temps when ridin slow through town or whenever you find slo stop and go ridin. As long as you aren't over heating I think you're ok.
Oh, to your question. No, mine hasn't done that yet. And was ridin in almost 100 degree heat through town just other day
yea i believe that is a pretty normal occurance, if the temps are in the upper range, if the temps r cooler and it is still doing it, then make sure the radiator cap is seated properly and the gasket on the cap is not damaged
