rpm's
Old Nov 23, 2006 | 01:45 PM
gottabfordtough's Avatar
Default rpm's
i guess i may just be used to cars and not high reving bikes. but is cruising at 85mph for an hour or so ok.. i mean i guess you dont have a choice it just seems like keeping high revs for so long may not be good? and like going through the neighborhoods. i usually go to like 3rd or so just cruising around 15 - 20 mph. should i stay in 1st or second and keep the revs up around 3,000? just a newbie bike question i guess. thanks.
Old Nov 23, 2006 | 05:43 PM
SirJAG's Avatar
Default RE: rpm's
huummmm well,
at 85 you should be in top gear, unless your racing or trying to be in the power band (7-12krpm)
around town my recomendation is to keep the bike between 3000-4500 rpm, lower than 3k and you will lag quite a bit, and if you need to hit the gas and move out of a bad spot quickly you wont be able too.
and remember theses bikes were made to beat on so to speak. if you have good oil, and do your reg. maintanence you could pretty much drive all day at 9-12krpms and be just fine. i have spent many a day at the canyons and track close to redline all day.
Dont worry about it my friend, if your doing something the bike dosnt like, you WILL know it. Trust your instincts.
James
Old Nov 24, 2006 | 01:43 AM
Boosted521's Avatar
Default RE: rpm's
these motors would much rather be at 8k rpms than 2k. like sirjag posted, try to keep them around 3k-4.5k or above. anything below 3k just bogs the motor.
Old Nov 24, 2006 | 04:19 AM
Blue Fox's Avatar
Retired Moderator
Default RE: rpm's
I think of it like this:
Let's say your car redlines at 6,000 rpm. At 85 mph in top gear, usually the car is anywhere between 3,000 - 3,500 rpm (half the rpm range)
Now, the CBR's redline is about 15,000 rpm. At 85 mph in top gear, the bike is usually at around 7,000 - 8,000 rpm (also, half the rpm range)
But, that's just the way I look at it. Anyway, I usually keep my bike in the 5,000 rpm range when driving around the city. You still get good gas milage (like I care) and still have enough power on tap to get out of a tight situation.
Hope that helps
Old Nov 24, 2006 | 11:46 AM
Default RE: rpm's
THANKS. YEAH I GET THE BOG THING ALOT. BUT I JUST DIDN'T WANT TO FEEL LIKE I WAS REVING THE MOTOR MORE THAN NECESARY. SOUNDS LIKE I JUST NEED TO GO DOWN A GEAR FROM WHAT IM USED TOO.
Old Nov 27, 2006 | 07:20 PM
Nevaeh Speed's Avatar
Default RE: rpm's
I keep her around 5500-7000, might need to open a can of wope *** on someone.... Stay ready so you don't have to get ready.[:@]
