Rear foot pegs
Decided to take off the rear foot pegs. The bike looks more fluid. Smoother cleaner, don't know what word to use to describe it. But on the right side there is a plastic peice that covers a heat sheild. And you can't put it on if you take off the rear foot peg. Top bolt on plastic has no where to go. So I just left it off and went riding. Alot more heat can be felt without that little peice of plastic. Not bad only if you put your hand on it. And the rear brake resovoir is sitting in the open.
Good idea or not and where can I get a repsol rear seat cover? No one seems to know.
do ya have a repsol ? then call 828-252-2280 and ask for the repsol solo cowl
i had the plastic exhaust shield for a while after i took off the passenger pegs - used a simple aluminium brace to secure the upper end
about the brake reservoir there's a number of options available ... G-Craft & Rizoma make billet reservoirs, Brembo makes a plastic one and some folks just use a clamped off HRC tube and a rare few use the M/C from the CRF450
I got my pass. pegs powder coated and drilled, then inserted 18 leds in each for blinkers. Looks pretty sweet. Check out this site. www.TripageLed.com
