Power Commander Required?
Old May 27, 2005 | 07:33 PM
RRip's Avatar
Default Power Commander Required?
Just called for an install price for a bolt on RS-5 and the guy told me he won't do it without a power commander because it won't run right. Is this true or is he smoking crack out his crack?
Old May 27, 2005 | 08:59 PM
chainstretcher's Avatar
Admin Emeritus & MVN
Default RE: Power Commander Required?
Edumacate me on the RS-5 -- is it a slip on or a full system? Just a slip-on I'd recommend buying it and doing it yourself - power commander optional. Full system I'd say go ahead and get the PCIII and have it mapped -- ya, I know that's adding another $500 to the price but a dyno tuned bike is sooooooo damn sweet.
Old May 27, 2005 | 09:09 PM
RRip's Avatar
It is just a slip on. I would do it myself but there are things I just do not know. For instance what is this box attached to the exhaust and do most after market CBR 1000 exhausts have bolt ons for this thing? Which pieces of the shiled do I remove permenantly? What else do I need to know?
[IMG]local://upfiles/1180/88393508F50445C8AC068B431C1AA70D.jpg[/IMG]
Old May 27, 2005 | 09:21 PM
MgA_ODEN's Avatar
It will run fine without the PC , it will run better with it .
As far as the install read up , it's easy . CBR1000RR Exhaust removal and Install
Old May 27, 2005 | 09:28 PM
MgA_ODEN's Avatar
Oh , and the RS5 should come with a big sheet of heat reflective tape , so you can toss the aluminum heat shield.
Old May 27, 2005 | 09:40 PM
RRip's Avatar
Thanks man. So what exactly if the difference between "Fine" and "Better"?
Old May 27, 2005 | 09:43 PM
The box with the cables is a flapper for the exhaust. Cables run to a servo under the tank on the left side. Just remove the cables -- do not remove or unplug the servo or it'll run like crap. I need to look into a way to bypass that. Anyway, which pieces to chuck and which to keep is a personal choice. I modded the brown-speckally plastic piece and some other stuff because it's how I like it. A lot of peeps chuck it all. Before you begin removing stuff have a plan and a good idea of what you want it to look like.
Old May 27, 2005 | 09:48 PM
MgA_ODEN's Avatar
The bike will run rich with this slip-on (go figure) so it will not hurt your bike , after I installed a PC3 , loaded a map and turned on the Accelerator Pump mod it rode like a different bike (smooth with a ton of power)
I still have plans on getting a custom map to wring out every last HP , I just dont have the $405.93 to put the bike on a dyno right now.
Old May 27, 2005 | 10:44 PM
Please splain 'Accelerator Pump mod'.
Old May 28, 2005 | 11:06 AM
MgA_ODEN's Avatar
It keeps the A/F ratio from spiking lean when the throttle is abruptly opened.
Accelerator Pump Utility
I'm at 75% sensiivity, 20% fuel add & 20 rotations.
My mods:
BMC Race Filters
Yosh RS-5 Slip-on
PCIII with Acc Pump Utility
Deactivation of Intake Flapper
