Only one turn signal working
Old Jan 3, 2007 | 07:58 PM
RRorXX's Avatar
Default Only one turn signal working
Hello RR lovers, I have turn signal issues, after changing the front turn signals to flush mounts they were working fine. I then Changed the rera tail ligh to L.E.D. to also incorporate rear turn signals, however NOW the right turn signal (front and rear do not flash, the front even luminate, the right work is fine. The iing is the same and fine. T thought at first that it could be the TURNSIGNAL RELAY SWITCH,but if that was the problemthe left wouldn't flash (right)? I was told i might need a load eqaulizer. WOULD THAT SOLVE MY PROBLEM?
Old Jan 3, 2007 | 11:07 PM
Blue Fox's Avatar
Retired Moderator
Default RE: Only one turn signal working
Do you have resistors or an aftermarket flasher installed when you put in the LED's?
Old Jan 3, 2007 | 11:31 PM
cbrrookie's Avatar
did you check your fuse box on the left mid fairing?
if one its burn't it won't give you the current.
Old Jan 8, 2007 | 02:48 AM
erbilabuc's Avatar
one of the wires for the front/rear right turn signals probably came off. Look into that before you get crazy and start ripping into other stuff. It happens a lot because the front wires can get snagged when the handlebars are moved if they arent routed in a certain way.
Old Jan 16, 2007 | 12:23 AM
RRorXX's Avatar
YOOOOOOO the load equalizer worked great
Adescendant
May 28, 2015 07:09 AM
pjrocco
Apr 23, 2010 01:38 AM
MrBlaze
Aug 17, 2009 02:07 AM
Cun0144
Sep 23, 2008 10:04 AM
2QK4U2C
Jul 9, 2007 11:22 AM
