off idle stumble
Old Jan 9, 2007 | 02:18 AM
acs1960's Avatar
Default off idle stumble
what's up ! i have an 06 1000rr, sometimes after a good freeway ride i pull up to a stop light idle 4 bit , upon take off i will get a slight instantaneous stumble , has anybody else had this problem ??
[/align]
Old Jan 9, 2007 | 09:45 PM
mininsx's Avatar
Default RE: off idle stumble
Nope, my '05 doesn't do it. Maybe your idle is set too low. It should be around 1100-1300 RPM. If you haven't done the flapper mod, do it. It's easy and it'll run smoother at lower RPM afterwards.
Old Jan 9, 2007 | 10:56 PM
acs1960's Avatar
thanks, i had the dealer check the idle, it is set to spec.i have not done the flapper mod. but i will try that , thanks.
[/align]
[IMG]local://upfiles/12719/10D29BF195F941369969784CB464C0AC.jpg[/IMG]
Gitter
F2 Tech
Sep 13, 2010 08:57 AM
Det99cbrf4
Sep 4, 2007 10:46 PM
mihomie
Jul 18, 2007 06:15 AM
78sharpshooter
May 9, 2007 03:30 PM
929ER
Jun 2, 2005 02:25 AM
