Need some advise
Old Sep 19, 2008 | 10:50 PM
Coop43's Avatar
Default Need some advise
Hey guys,
found a good deal on a local bike has a major issue though.. his add states this below
"Bike is rideable but it does have a miss to it. After inspecting the bike I know that its only running off of 3 out of the 4 cylinders. Spark seems fine so I think the cylinder head needs some work done. Does not overheat or knock. Just has a miss to it. I think some resurfacing to the heads and valves will cure the problem."
does this sound like a major internal problem or something that is worth fixing.. the bike is an 04 i do not know the milage but it looks to be in decent shape and hes asking somewhere around 3 to 4k range
any help would be greatly appriciated
thanks
Old Sep 19, 2008 | 11:17 PM
rellimdekim's Avatar
Default RE: Need some advise
Man personally I would steer clear of that. Anytime you get into a bike that is having a problem like that there is a lot more going on then you are being told.
Old Sep 20, 2008 | 01:38 AM
WhiteKnite's Avatar
June 2009 ROTM
+1 to that. If it was worth it to fix, he would probably fix it first and then sell it. I wouldn't even consider it.
Old Sep 20, 2008 | 02:59 AM
HAVOC's Avatar
im not one to shy away from a project but this one makes even me step back. if you are truly interested take it to a professional mechanic before you buy it and have it examined. cause this guy might be an idiot and it just has a fouled plug or something easy and he is thinking worse case scenario
Old Sep 20, 2008 | 03:02 AM
kamikaze2899's Avatar
I would stay away from this one. You can find a bike w/o that problem(s) for the same price. Could be a simple fix, or you could end up with someone elses lemon with no way to make lemonade.
Old Sep 20, 2008 | 07:54 AM
WhiteKnite's Avatar
June 2009 ROTM
ORIGINAL: HAVOC
Not so sure I would want a bike that was owned by someone like that though either, lol
Old Sep 30, 2008 | 10:33 PM
Ryda Girl's Avatar
Try talking the price down. If he goes for it then part the bi@tch out.
Ching ching
Old Oct 1, 2008 | 01:34 AM
justasquid's Avatar
I'd steer clear too. If he is talking about internal engine work... theres a good chance there is something he knows that he is not telling you. Normally, a miss would be related to spark plug or faulty injector. that would be my first impression..his is internal engine work? Hes hiding something.
Robbie
Jun 6, 2010 06:02 PM
600F4inoober
May 27, 2010 11:51 PM
TattooguyF4i
Mar 1, 2010 08:19 PM
gerharddvs
Nov 8, 2006 06:53 PM
HoneyRican
Nov 27, 2005 09:21 PM
