kNOCKING AND PINGING
Old Jun 18, 2006 | 08:04 PM
redloop's Avatar
Default kNOCKING AND PINGING
MY BIKE IS 230 MILES OLD AND SINCE I PIKED IT UP UNDER SLOW STARTS IT SEEMS TO BE ALITTLE SLUGISH UNTIL 3000 R'S, AND AT TIMES IT SEEMS TO KNOCK AND PING UNTIL 3000 R'S DOES ANYONE KNOW IF THIS IS NORMAL OR NOT.
Old Jun 18, 2006 | 08:26 PM
cbr04's Avatar
Default RE: kNOCKING AND PINGING
that doesn't sound good. i rode a new 1krr with like 500 miles on it... SMOOTH. i'm no master mechanic but IMO there shouldn't be any "knocking/pinging"... EVER.
Old Jun 18, 2006 | 09:22 PM
SirJAG's Avatar
well based on the info you provided.... no totally not cool, let the service guy where you bought it listen to it...
good luck,
james
Old Jun 19, 2006 | 02:12 PM
corrcullen's Avatar
am i right in saying that the pinging knocking noise occurs when you load the engine at low rpms, with the 05 model?
Old Jun 19, 2006 | 05:29 PM
chainstretcher's Avatar
Admin Emeritus & MVN
Lugging the 1000, especially up a hill, will cause it to knock a bit. Solution is to give it what it wants -- more throttle in a lower gear
Old Jun 19, 2006 | 06:36 PM
jerrad's Avatar
Maybe some bad gas, but that wouldn't explain why it goes away at higher RPM.
Old Jun 19, 2006 | 07:48 PM
mininsx's Avatar
They all do it. Just be sure you've got 91 octane or better in the tank. My buddy has an '04 1Krr and his makes the same noise that my Repsol does. His old GSX-R 750 was worse.
Old Jun 19, 2006 | 09:57 PM
redloop's Avatar
THANKS FOR ALL THE RESPONSES. TODAY I STARTED OF ALITTLE HARDER AND, I THINK YOU GUYS ARE RIGHT. IT WAS DOING IT ALOT LESS, I GUESS I WAS OVER KILLING THE BREAK IN.
Old Jun 20, 2006 | 02:11 PM
rdracer134's Avatar
Check you cam chain tensioner... in the F3s, they were very likely to wear out and needed to be replaced, usually with a APE manual tensioner!
my .02 cents
MT
Old Jun 20, 2006 | 03:00 PM
AZ1000rr's Avatar
Hope your problem is solved. My 06 doesn't do that, unless of course i am in too high of a gear for the speed and rpms....I ran my bike under 5500 most of the first 600 miles, with a couple of 4,5,6 gear blasts upwards of 9k rpm. have almost 700 miles on it now, and she purr's like a fat and happy cat. I am taking it in to the dealership for service, hopefully this week, as all my mods are in except my pipe which should be here thursday. If you aren't 'in the wrong gear' so to speak, I'd really let the dealer check it out, honda's are very reliable, but any bike can have a factory defect, best to be sure since it's under warranty anyway
