How do you clean your rear wheel?
Old May 13, 2008 | 10:19 PM
lungfish13's Avatar
Default RE: How do you clean your rear wheel?
I also use simple green. Doesn't leave any residue.
Old May 14, 2008 | 03:44 AM
camaro_forums's Avatar
If you keep your wheels decent, you'll only have to use windex. Thats what I did today, just wiped the grime off with windex, didn't even have to use the wheel cleaner. Of course maybe I"m just not throwing that much grease down anymore, who knows.
Old May 14, 2008 | 03:49 AM
bananazx's Avatar
I am surprised that WD-40 could be used to clean grease on the wheels.
Thanks.
Old May 14, 2008 | 04:58 AM
Bishop1981's Avatar
Same here. The WD-40 works wonders on the wheel and chain. Actually, I haven't use chain lube on my bikes in several years. I was tired of all the gunk from the chain lube. The kinda I had was chain wax. It goes on clear but endsup black. Also, I noticed grits of sand from the road stuck to the chain worse also. Which can't be good for it. All, I use to lube them now is WD-40. It keeps them from rusting too. I had 13000 on my 954's chain when I traded it. It still was in great shape.
Old May 14, 2008 | 06:01 AM
Dbailey226's Avatar
Go to WD-40 website. There are over 1,000 uses for the 40. Cleaning is one of them. The stuff works miracles on grease, bugs and tar. Lots of people in the Automotive detailing business use it!!!
Old May 15, 2008 | 01:18 PM
bdphap's Avatar
Thanx for the WD40 website, I am now a firm beliver of WD40 for mosteverything. I work in a shop and didnt know it could be used for most stuff Thanks again.
Old May 15, 2008 | 06:22 PM
Bishop1981's Avatar
I use WD-40 under my truck. I hate rust. I normally spray the leaf springs, drive shaft, and axles downevery month or two. I just let it soak in. The truck is 8 years old and everything looks black as coal under it.It hasvirtually no rust.It Really helps when you go to the beach and get near the salt and, also in winter when they cover the roads with sand and salt.....
Old May 15, 2008 | 11:24 PM
VP's Avatar
VP
Just make sure if you get WD40 on your tires or brake pads...to never ride your bike again.
Old May 16, 2008 | 06:40 PM
amazingbike's Avatar
Yup .... WD 40 it has many uses dude... but I've use to clean it by De-grease spray but after that I need to grease the chain again ... from now I'll use WD 40
I Think that's better
dyracuse
Apr 15, 2010 04:51 PM
Lgr12
Jun 21, 2006 01:06 AM
