frame slider question for the 2006 1000rr
Old Jul 7, 2006 | 07:06 PM
ciceman's Avatar
Default frame slider question for the 2006 1000rr
where can i get a set off the cut style frame sliders and who all makes them, also has anyone seen the new micron exhaust for the 06 1000rr yet? or know anything about it?????
Old Jul 7, 2006 | 08:05 PM
livinlife2themax's Avatar
Default RE: frame slider question for the 2006 1000rr
i know that there are not many companies makin anythung for our bkes yet... I even contemplated just cutting through my fairing until i saw that with how the fairing is mounted and where the slidder goes it is nearly impossible, it would get in the way of one of the mounting screws and be on the edge of the plastic..I did however find soe no cutt sliders on ebay they are made by Derlin... i dont know how ggod they are, but they are made for the new 06 1000rr. I would rather have somethin than nothing...cause you never know when you might have a accidental tip over in the garage... the sliders were only like $49 however i did see a set of shogun sliders, sppols and handelbar ends for $122. just go in ebay and search 2006 cbr frame sliders. or something of that sort..
Old Jul 7, 2006 | 11:34 PM
Bake13b's Avatar
hey i got the shogun frame sliders on my bike. they sit a bit further back then i like but they were a quick install all you have to do is remove the side fairing and the front motor mount. replacement bolts and spacers come with the kit. did not require any cutting or mods to the fairing.
Old Jul 8, 2006 | 03:41 AM
mannyrios's Avatar
Check out this site. I have purchased from them before... pretty good.
Old Jul 9, 2006 | 03:35 AM
Boosted521's Avatar
lightech sliders are really nice.
Old Jul 9, 2006 | 08:12 PM
kiggy74's Avatar
Avoid the Shoguns at all costs. They save you from having to cut plastic, however if you drop the bike on it's right side (even if it's not moving) the slider will jab itself into an elbow that moves water back to the radiator. It will at least bend the elbow if not break it. To repair the elbow requires dropping the engine for repair, which is big time expensive, much more so than new plastic.
I've got an order in for the Lightech no-cut sliders from www.OPPracing.com. They seemed to be a little more robust than the Shoguns and aren't supposed to bend into any engine components if dropped. I'm still doubtful, so I'm anxious to see how they look.
Old Jul 10, 2006 | 02:56 AM
DrDRFT's Avatar
does anyone know where I can get stuff for my 06 thou in Melbourne Australia? You guys seem to be able to get all the cool stuff but I cant get anything for my blade here![:@]
Old Jul 11, 2006 | 12:41 AM
kiggy74's Avatar
Yikes, sorry chief. If it's not near Columbus, OH, USA I'm not going to be much help to you.
Old Jul 11, 2006 | 05:32 PM
RR Pilot's Avatar
I thought the Lightech no-cuts would be cool too.
Til I bent the right side with my shin.
No, the swelling hasnt gone down after 3weeks.
I bent it back only to find the support bracket is cracked.
I went against my better judgement with the no-cuts and thats what I get.
Pretty expensive lesson.
Im looking at the Woodcraft cut style because those asswipes at Yoyodyne still dont have a definitive 06' model.
Then again, Eric Wood at Woodcraft couldnt give me an answer either. "Uhhhh, a dealer said they would work..."
Thanks guy, Ill place an order right now...sheesh.
Old Jul 11, 2006 | 06:32 PM
kiggy74's Avatar
Bent it with your shin? Are you serious? Either the slider is weak as heck of your shin is tough as nails. Which is it? Cause I got a set a Lightech on the way and if they are crap I'm sending them back. For $130 they should NOT be crap.
