Does a higher gear ratio read faster or slower on a speedo…
Old May 17, 2024 | 10:18 AM
Hachi1000RR's Avatar
Default Does a higher gear ratio read faster or slower on a speedo…
‘08 CBR1000RR Gear ratio question…
Current: 42/16 = 2.625
Proposed: 42/15 = 2.8
%age difference: 6.45
Stock, my bike’s Speedo reads 6.66% (approx) fast.
If I regear to the proposed higher gear ratio, I think it will bring the speedo close to center (6.66-6.45=.21% fast).
Am I thinking correctly here? I’ve no experience in this area.
Thanks in advance.
Old May 17, 2024 | 02:11 PM
dannoxyz's Avatar
Might be opposite. Adjustment to make here is ratio of output-shaft speed vs. rear-wheel speed. By going with higher gear-ratio, you'll spin engine and transmission output shaft faster for same rear wheel & road-speed. So will make speedo error even worse.
You'll want to go in opposite direction with 42/17 or 40/16 to slow down engine & transmission speed for same road-speed.
Old May 17, 2024 | 03:08 PM
Thank you for your time.
asides
Feb 6, 2010 09:29 AM
Monstrosity
Dec 28, 2009 08:05 AM
land_warrior.rus
Sep 30, 2007 08:09 PM
TeeDub
Nov 16, 2005 12:50 AM
L8X
Mar 21, 2005 06:59 PM
