cbr 1000 overheating???
Old May 12, 2011 | 10:56 AM
alrepsol1000's Avatar
Default cbr 1000 overheating???
i got he bike 2 seasons ago and found it over heating as i come from highway speed to a red light at city, i changed thermostat, backflushed and forward flushed cooling system 3 times, good compression and no leak down, and still over heating, i was wondering if the aftermarket 2 brothers exhaust could cause this. and if so could pipe wrap and another cooling fan help? would be grateful for input thanks
Old May 12, 2011 | 11:21 AM
RoadiJeff's Avatar
Senior Member & Lord of The Man Cave
Describe what it does when you think it is overheating. Just because one or both fans come on it doesn't mean it is overheating. When you come to a stop from highway speeds the engine temp will rise because the airflow is no longer there.
If you want to cool it down a bit in stop-and-go traffic or warm weather at stoplights install a manual fan switch. I posted a how-to article in the 1000rr section. For around $5 in parts and a bit of time you can do it without too much difficulty.
Old May 12, 2011 | 05:55 PM
nakedcivic's Avatar
do the 1000s not have a temp gauge ? whats is it reading ?
Old May 13, 2011 | 09:00 AM
mininsx's Avatar
"Running hot" (which they all do) and overheating are two different things. If your bike's temp light is on and it's puking coolant onto the pavement then it's overheating. Make sure you've got all the air out of the cooling system. Even a little air will cause problems.
Old May 14, 2011 | 04:26 PM
224 spitting coolant hot and fan turns on its an 05
Old May 14, 2011 | 04:27 PM
124c ^
Old May 15, 2011 | 02:26 AM
revilingfool's Avatar
my fans turn on at 219 Fahrenheit. 224 should not be overheating, best of luck
Old May 15, 2011 | 06:50 AM
MadHattr059's Avatar
Check the thermostat. If it's sticking, it can restrict or close off, coolant from flowing thru the engine. Also, be sure the fins/air flow isn't blocked on the radiator itself.
As far as the exhaust, if it's forcing the engine to run lean, then yes, it could be a contributing factor.
Ern
Old May 15, 2011 | 11:16 AM
RoadiJeff's Avatar
When you did all the coolant flushing did you burp the system to make sure there's no trapped air? Also, the fan being on at 224*F is normal. If the coolant recovery tank is overfilled it would cause it to discharge coolant when it gets hot and expands.
Old May 17, 2011 | 11:15 AM
Just 124 C 224 was typo and thermostat is working and is brand new
