-   CBR 1000RR (https://cbrforum.com/forum/cbr-1000rr-13/)
-   -   both headlights on instead of one ?????? (https://cbrforum.com/forum/cbr-1000rr-13/both-headlights-instead-one-4555/)
Repsol JF Sep 15, 2005 07:22 PM
Anyone knows how to bypass the headlight on the Repsol? Instead of running with ONE light on (the regular beam) is it possible to run with both headlight on? Please help.
MgA_ODEN Sep 15, 2005 07:41 PM
RE: both headlights on instead of one ??????
Run both , adjust high beam down.
Anubis Sep 16, 2005 12:52 PM
ORIGINAL: MgA_ODEN
+1 yep.
Whippet Goode Sep 16, 2005 01:58 PM
The relectors for the low beam/high beam side are not the same. They project the light @ different angles/rates.
Cheers
shinysideup Sep 16, 2005 08:41 PM
im still going to try to rig it so you can have 2 low beams, and 2 high beams
MgA_ODEN Sep 16, 2005 09:17 PM
Let me know how that H4 bulb conversion turns out.
I know with money and time it can be done (new bulbs,relays,wire,euro reflector housing , etc ,etc.)
I just cant justify all the work.
shinysideup Sep 18, 2005 12:20 PM
ok, so i took a look at the factory set up on the lights and this is what i concluded. the stock plug has 3 slots for electrical connectors while only 2 of them are being used (one for power and one for ground). i am going to see if i can find some dual fillament bulbs that fit the headlight housing and replace the originals. then, i am going to use the 3'rd/not used connector on the plug to hook up the second fillament. my plan is to splice the hig beam light from the right light to the plug on the left light that would run the high beams, and the same with the low beams. i am guessing that will make both lights low beams and high beams, and still operate on the same switch. ill let you know what happens, unless someone beats me to it. if it works, ill leave you guys some detailed instructions on how to do it. it doesnt look like it will be that hard, but i wont really know until i get into it. also, all you should need is 2 new bulbs, a couple of wires, and some electrical connectors.
MgA_ODEN Sep 18, 2005 01:40 PM
ORIGINAL: shinysideup
Your going to run into a few problems doing it that way , first the reflector housing is different on both sides so if you use a H4 bulbs (stock is a H7) it will be like running your bights anyway.
Second , trying to pull extra amperage through the stock wiring harness is a good way to melt wires , blow fuses and kill your ECU , hence the relay reference in the post above.
If it works out for you great, but you may find that aiming your high beam lower and just running both is a easy fix.
shinysideup Sep 19, 2005 02:48 PM
i feel real stupid now. i just got finished hooking it all up. now im scared to turn it on. it worked initially, but i guess im going to take it all off before i ride it anywhere. screw it, im just going to run highs. are you sure? the lights i got were the same wattage, although i do know that i am running 2 lights on dual elements now. im taking it off!!!!!!!!!!!!
Blue70 Sep 19, 2005 03:10 PM
I blew a fuse trying to run both lights by jumping one side to the other (with H4 bulbs)
Worked fine untill I went on a longer ride (in the upper RPM range ;) ) but then I was stuck with no lights.
It should work fine with all new wireing and relays, but don't try to cheat like I did :(
But MgA_ODEN is correct, the bright one does throw light different and still looked like the high beams were on even with only the lows on.
