Axel nut size
I really have no Idea....it may depend on few things....Are you using the stock bearings with the wheel? Does the wheel manufacturer recomend anything?........To be honest..... that axel see's a lot of torque......I dont know that I would trust anything less than the manufacturers specs......... When you think about it, you have the chain adjustment bolts to help hold the left side when under power but for braking or gearing down, nothing holds the right side except the torque on that nut.........just a thought.......
Torque wrench and socket is cheap compared to going down.......
I had an old 1 1/4' socket that works perfect for the axle nut. Would use a torque wrench every time ... expecially with aftermarket wheels. If you have any doubts contact the manufacturer about proper torque.
And for any newb types that don't know, this is a flame free forum. Smart assed comments should be kept to yourself [:@]
ORIGINAL: toptaz1000rr
its no diff.. it IS 83ftlbs
aftermarket rims is 1/2 of that
correct......you cannot do damage to the wheel by torqueing it to the stock specs...including carbon wheels....the axle tightens on a steel spacer tube thats between the bearings....you cannot crush the wheel.......84 ft lbs.
I have magnesium Marchs.....and they say stock spec on the torque
