2006 CBR1000RR Fireblade Dash lights out
Old Dec 2, 2023 | 01:06 AM
kadeklonowski's Avatar
Originally Posted by dannoxyz
Not a problem with dash. Turn signal indicator only follows what turn-signals are doing. If flasher-relay is broken or circuit got mangled by LED winker install, then if turn-signals don't work, perfectly OK signal indicator on dash won't work either.
So. Went for a ride tonight. Had to bump start it initially, but then it ran fantastic. When I went to get gas and turned the bike off, the bike started with no issue whatsoever. Turned it off about 3 more times tonight and it started back up no problem. So I guess this sounds like a bad battery like what was said initially. I appreciate y'all's help.
Old Dec 2, 2023 | 06:19 PM
dannoxyz's Avatar
Not likely battery because if it died due to weak battery, it will not start up again.
Sounds more loose/broken wire or corroded/loose connector somewhere.
cbrHurricane
May 16, 2009 10:59 AM
jimba
Nov 9, 2008 08:52 PM
3dgar RR
Nov 5, 2008 05:20 PM
Roket_Texas_usa
Jul 9, 2006 06:10 PM
