05 1000rr
Old Dec 7, 2008 | 06:03 AM
ohriley's Avatar
Default 05 1000rr
was up,
I boughta 2005 cbr1000rr a few days ago, and have been nursing it back to health. (will post pics soon)
I have come across a problem with the turn signals.
they dont work. i have checked the fuse and its fine. the horn, and tailight work. but no signal action.
i do not have the hesd hooked up. would this cause the problem?
anything would help.
lates
Old Dec 7, 2008 | 07:43 PM
CBRjosh1000rr's Avatar
Default RE: 05 1000rr
Have you checked the wiring, trace it back to the bike and see if there is a cut in wiring, does it have flush mounts or stock turn signals, whoever hooked them up may not have known what they were doing.
Old Dec 9, 2008 | 11:15 AM
jwp6114's Avatar
PM me and i can e-mail you a picture of the wiering diagram if you dont have the manual. Or i can try to get you a copy of the maintenance manual with wiering diagrams.
Old Dec 9, 2008 | 11:48 AM
ohriley's Avatar
pm sent!
Old Dec 9, 2008 | 01:09 PM
TK954RR's Avatar
Jan 2009 ROTM
Well im assuming it crashed then yes? Maybe the bulbs just broke/burnt. Get a test light and see if your wires are hot before you go too far.
Old Dec 14, 2008 | 10:37 AM
toptaz1000rr's Avatar
make sure the wires are plugged in fully (behind under the tail section)
plug the hsed IN.. SOMETIMES there small glitches that are all related to each other
Old Dec 22, 2008 | 12:46 AM
ohriley's Avatar
heres a pic~ ill get better ones once i fix a few more things...
I'm still trying to figure the wiring out. it has flushmounts, hotbodies in the front... (so ive done the 'search' on how to wire them up)
For some reason when i engage the turnsignal switch. nothing happens on the indicator display, and no action in the front and rear signals as well.
could this problem maybe be the signal relay?
i did plug in the "gpr" damper adapter, so i got some HP. back!
the search continues... laters
Old Dec 22, 2008 | 05:34 PM
DWT74's Avatar
Its been awhile so im not real sure but i thought if either side front and rear wasnt hooked up the blinkers will not work. Correct me if im wrong.
Old Dec 22, 2008 | 10:19 PM
ohriley's Avatar
well; when i got the bike, it didnt have the licence plate lights hooked up. the turnsignal lights were all hooked up.. i didnt really put two and two together before i started hacking away at the wires. ill try hooking everything up and see what happens.. i hope its that easy!
Old Dec 23, 2008 | 01:56 PM
DWT74 one side will in fact work if the other doesnt.
