05 1000 RR key question
Old May 16, 2007 | 03:44 PM
jim hugo's Avatar
Default 05 1000 RR key question
I just purchased a use 1000RR,I have not recieved the owners manual yet. The ignition and key switch worked fine when I picked up the bike,then I took the key out and went out of town for a few days,now the key will only go in half way,is there a lock out that I dont know about?
Old May 16, 2007 | 04:15 PM
Onarom's Avatar
Default RE: 05 1000 RR key question
You might want to try a graphite based key lubricant, but you shouldn't have that problem. I think I would go back to the dealership.
You don't have the european modle with the H.I.S.S. system, do you? (it would be clearly marked by the key hole)
Old May 16, 2007 | 04:31 PM
CBRCRF's Avatar
ORIGINAL: Onarom
Whats that?
Old May 16, 2007 | 06:34 PM
Onarom's Avatar
[hr]Honda Ignition Security System (H.I.S.S.)
Honda's highly capable H.I.S.S. anti-theft system features a fail-safe electronic interlock that prevents the engine from being started in any other way than using the motorcycle's two original keys. Totally disabling the engine at the very heart of its ignition system, the system cannot be bypassed by either hot-wiring the ignition or exchanging the ignition switch module, thus effectively deterring joyriders and greatly reducing the possibility of ride-away theft.[hr]
Unfortunately, this is not avalable in the states. I wish it was!
Old May 16, 2007 | 06:37 PM
CBRCRF's Avatar
No kidding! You would think here it would be a must have. Oh well, Ill just get lo jack.
Old May 17, 2007 | 12:17 PM
jim hugo's Avatar
I have now learned that someone has broke a key off in there,its a bitch to remove the bolts holding the ign. switch to the triple clamp,they are tamper proof and have to be drilled out,good thing is,I have a drill press and the heads drilled off fairly easy.
Old May 17, 2007 | 02:19 PM
CBRCRF's Avatar
Wait... Did you break the key on accident and didnt know it? If not thats amazing that the key worked when you first got and now it only went half way in.
Old May 17, 2007 | 06:50 PM
ali's Avatar
ali
hi mate i've had the same thing happen a couple of times in the last week with my 05 and the key was just and i do mean just bent. the key must be made from really soft metal so watch when taking the key out of the ignition or seat lock which is where i bent my key. hope this helps.
Old May 25, 2007 | 06:27 PM
jim hugo's Avatar
What happened is I went out of town for a few days and when I was gone my son was going to fire that beauty up,however he used the wrong key in it and snapped it off........and did not tell me.....so I got home and put the correct key in, pressing the piece of key deep in the tumbler.Its all good now,thanks for the help.
Old May 25, 2007 | 08:23 PM
CBRCRF's Avatar
OOOHHHHH! Ground him for life!!!J/K!
