04 bogging problem?
Old Jun 3, 2007 | 09:17 PM
ryko9's Avatar
Default 04 bogging problem?
got a 04 1000rr and latley in the middle of a hard ride the bike starts bogging out ,coughing or like its gona stall. also the speedometer dash will turn off and on?? any ideas could the ecu be shot or plug wires gone or something electrical? it does have a aftermarket exhaust and burning a bit rich but i need to figure this prob out any help would be great thanks
Old Jun 3, 2007 | 10:00 PM
mininsx's Avatar
Default RE: 04 bogging problem?
Check your battery connections. Maybe one of 'em is loose. Do you have a PCIII?
Old Jun 3, 2007 | 11:21 PM
ryko9's Avatar
no, no PCIII
Old Jun 4, 2007 | 12:59 AM
Onarom's Avatar
Aftermarket turn signals? They are connected to the same fuse. I had a short from my rear turn signals that caused my dash to go out (minus the RPM gauge)
Old Jun 4, 2007 | 12:35 PM
ryko9's Avatar
yes aftermarket turn signals all four, did it cause the bike to bogg out to or just short out dash, how did you solve the problem , rewire, or change fuses?
Old Jun 4, 2007 | 07:21 PM
Onarom's Avatar
For me, it caused the short in the dash. Take a close look at the wires and make sure that they are not exposed and "groungding out" to the frame or other metal surfaces. I rewired my rear turn signals and everything was fine.
I hope that is the problem. It would be an easy and cheap fix
Old Jun 4, 2007 | 08:35 PM
ryko9's Avatar
all light wires are good, so that is fine, does antone no if not having a power comander to remap for a slip on exhaust would cause the bike to spudder at steady throtleor almost stall at idle and flick speedo gadge of f and on sometimes? or do i have a more serious prob here
Old Jun 4, 2007 | 10:32 PM
ryko9's Avatar
could a shot stator cause theses probs?
Slavo04
Jul 17, 2009 01:10 PM
evo8
Jun 2, 2009 12:30 AM
marsolais
May 6, 2008 09:03 PM
f4ikid05
Mar 8, 2008 03:40 PM
J Boogie
Mar 23, 2007 03:45 PM
