04 1000rr crank but won't start has fuel prime
Old Apr 1, 2014 | 08:46 AM
shizz's Avatar
Default 04 1000rr crank but won't start has fuel prime
Ok what's up guys been a while since I have been on here
04 1000rr just cranks smells like gas pump primes and I have spark put new plugs in it and still nothing, bike is tore down checking everything I am at a loss. All I did was put a new stator cover and took the clutch apart and put a factory pro shift star in and new plates and fiber and had my new clutch cover on went to start it just cranks . I changed the sensor out on the clutch cover still nothing. Unhooked the pc5 still the same.
Any help would be great
thank you
any help would be great
Old May 4, 2014 | 11:38 PM
clayton130's Avatar
Sounds like the same problem I have. Broke down on the road 600km from home Yesterday.
Bike dead, swings but no spark/fuel clocks are on but pcv says it has no power. Disconnected the pcv but still nothing.
Turns out i popped a small fuse next to the main fuse under my seat near the battery and main fuse. It is a 20amp in a small holder.
I changed it and popped again after 5km. Not sure what it is but may control the fuel and PCV somehow.
Old May 5, 2014 | 01:21 AM
clayton130's Avatar
I just checked the manual, it's my FI fuse but the FI light didn't come on to indicate the problem.
Check if yours is not fused.
prodigy361
Nov 26, 2013 08:31 PM
Nicholas Scalisi
Jun 24, 2013 08:07 PM
G_954rr
Oct 26, 2011 04:52 PM
Iceberger
Aug 22, 2011 03:06 PM
adamw89_2000
Aug 12, 2010 02:18 PM
