is this worth buying?
I recently found a 1987 cbr1000 black and red near me for $800 obo. Its got 10k on it and looks to be in really nice shape cosmeticly from the pics. Its owner says it doesnt run (havent gone to check on it yet) From what he says Im leaning toward the idea that its been sitting for quite some time and has fouled the carbs.
ASSUMING: the carbs need to be rebuilt and fluid areas need to be cleaned, but the rest is mechanically sound and in nice shape...is this worth $800? if not what would be a good starting point?
thanks
Jason
thanks
Jason
If you like a challenge and working on your own bike then it sounds like a reasonable price. But anytime you buy one that isn't running there is a chance it is something major. I would find out if it will at least turn over. Would give you a better idea of internal condition.
the owner says it turns over fine with a good battery...bring my own fresh one when i go to look at it. I really think its just been sitting for a long time...but will find out more when i get there this weekend.
ORIGINAL: swisherred
thanks
Jason
thanks
Jason
$800 for a bike in good condition is a great price.
If you decide to buy it, you must change the tires. If the bike has been sitting the tires may look new but are crap. Ride safe!
It would definately need new rubber, probably new brake lines and water lines by now as well....I always figured that if it turns over then everything else is little stuff, but I dont have alot of experience with the cbrs...just an 89 600 'cane that I had for a short time...fell in love with that, but had to get rid of it...now Im thinking this 1k is the way to go.
Is there anything in particular I should look for (that may not work) on this bike when I go to look at it? I know brakes, clutch (is that hydraulic?), wheel dents/bends, lights, gauges, tank rust, check the oil, radiator for leaks and rust..
thanks guys....
thanks guys....
If you could buy it for $800.00 and the plastics are in great shape, it is a bargain. A good set of plastics alone will sell for more than that on EBAY. If it's been sitting awhile with gas in the tank, chances are the inside of the tank is probably in bad shape rust wise. I have found while restoring mine the electronic bits are much more expensive to acquire than the mechanical pieces. Good luck. If you decide to buy it and later want to sell the plastics emial me,
Jeff
Jeff
This may help................
http://myweb.tiscali.co.uk/midlife/i...ice_Manual.pdf
the right one
HOW TO VIDEOS
http://www.youtube.com/profile?user=...mp;view=videos
the right one
HOW TO VIDEOS
Mine sat in the shed for way too long. I had the tank cleaned out and lined, the carbs disasembled and completely cleaned, new battery and tires and I was good to go.
I think its a great deal if its otherwise in good shape.
If it cranks over with a new battery, try to do a compresson test. At least if that check out, you'll know that the engine is probalby ok. Find out why was the bike parked in the first place.
Even if it needs an engine, for $800 is a good deal. Got mine with a blown cylinder for $800 too and looks like it will costaround $250 in parts to get it running again (I do all my own repairs).
