working with alum
on
gittin' all productive and chit :-)
Might cheat Ern - use JBweld and a piece of right sized 1/4 thick flat stock and
sammich it together drilling the center hole through both pieces once cured
Between the center hole and the bolt going through it with JBWeld it's sure
to hold. leaving 1/8 " all round
Might be a damned sight quicker than machining the outer 1/8 'L" and the inner
piece can't be seem inside the swingarm anyhow. seems the easiest quickest way
to do it !
Plus I have 4 of these to make ! lol
edit : merge and bump &......... a beer
So this is what 45 mins out in the garage produced
inner plates get jbw'd onto the blocks and then drilled
thru' , spools eventually tapped on the side
to do it !
If you want to be really sure. After you epoxy them up, drill a couple of discreet holes.
All of the way through both plates. Then get a couple of drift-pins and tap them in.
That will lock the plates from rotating around the adjuster-rod, once you've drilled for that.
It will add a very strong sheer element to the plates, since the spools will be creating
a rotational force because they are on only one side.
That's if I'm correctly understanding your design.
Ern
Ern
