Wont start when hot, slow crank like battery dead but not dead
Old Jun 3, 2010 | 01:10 PM
WhiteHawk's Avatar
UPDATE:
So I went riding the other day.
1. 50 mile ride to destination
2. Bike sits for 30 minutes, immediately starts
3. Go 500 feet to bank #1
4. Bike sits for 5 minutes, immediately starts
5. Go 1 mile to bank #2
6. Bike sits for 5 minutes, slow crank, battery seems dead, wont start
7. Roll bike down hill and drop into gear, starts immediately
I went straight home. Then kept testing the starter after I got home, to repeat the condition, couldn't get it to happen again...
With this, is it for sure the Starter Damper? Starter Clutch? The Battery?
Old Jun 3, 2010 | 01:16 PM
WhiteHawk's Avatar
Originally Posted by 3v1lj03
I have the hard starting thing when it's hot. It does not sound anything like that video shadow posted. It sounds like the battery is almost dead. If you let it cool awhile(10 min) it will start just fine. I have suspected it is just a weak started motor as I had the same problem in a 1968 Chevy Nova same symptoms even.
I second that, it doesn't sound like the video, just like the battery is almost dead. I guess with my initial incident, it did start right up the next morning.
Do we just have to throw money at it? I lost my JOB last summer, I need this bike to SAVE money over the summer =(
Old Jun 3, 2010 | 02:06 PM
Indiana Hurricane's Avatar
Senior Member & 2010 ROTY
I think you have a busted wire. Where the insulation is not broken threw. But the wire inside is busted or corroded
Old Jun 11, 2010 | 01:18 PM
WhiteHawk's Avatar
Was moving wires around and checking for resistance, however this is not a very good test cause one single strand will show continuity.
I just ordered a start relay, maybe its corroded inside? I will try it and see what happens...
Old Jun 11, 2010 | 11:25 PM
Shadow's Avatar
Check the earth on your frame where ever you have one, especially on the ignition circuit. Maybe corroded or loose.
Starter relay also a good idea...................
Old May 28, 2013 | 01:57 PM
WhiteHawk's Avatar
Crap, I never followed up:
I installed a new Motobatt AGM SLA battery, works wonders no more issues. So I changed the RR and put an upgraded battery in.....
Old May 28, 2013 | 02:23 PM
hawkwind's Avatar
Well done on the up-date Hawkman! Even if it is a couple of years late
Good to know the Motobatt battery worked it's magic. These old girls do need a good jolt of juice to fire them up.
Old May 29, 2013 | 11:14 AM
TimBucTwo's Avatar
Yep! I hate loose ends.
Old May 30, 2013 | 09:56 PM
Sprock's Avatar
Gee whirlickers - I wuz wonderin' all about that !
Old May 31, 2025 | 07:11 PM
dauymkatana's Avatar
Default solution?
was there ever a solution found?
Dazed
Apr 13, 2012 06:58 PM
nightmarenyc
Apr 4, 2012 11:21 PM
fatluke_nofx
Mar 20, 2012 07:44 PM
TurtleSLow
Apr 8, 2011 07:24 AM
mhatley
Feb 3, 2009 02:05 PM
