won't city start
Odd place to shift. Don't you know how gearing works?
ha ha ha .............you beat me to it Joe .........LOL
Joe, you've made several comments that indicate that it's not me that doesn't know "how it works".
In response to shadow saying that the charge doesn't kick in until 3k rpms.
Good info there. May need to upshift less when noodling around.
It's only because it has so much torque that you can do this.
And since I hate to abuse my equipment, I usually let it loaf when I'm stuck at 40 or so.
Buster, what I would do is wait for the bike to have the problem and then start checking stuff. Do exactly what CBRClassic suggested on the fuel end, and then pull a plug or two and make sure you have spark when it's doing this and go from there.
If you don't have spark, you could be having electrical problems from the heat....ie coils heating up etc.
More info would be good, too, like shadow said.
Just had a chance yesterday to start the bike....bad weather, buying a house, new g.f....yada...
So I start it cold, no problem as usual....bring it up to temp and then I lift it upright off the kick stand and....drum roll.....it stops...what???....so I put it back down on the stand and it starts fine....upright...stops....I drained the carbs...then hot wired the fuel pump to refill them and.....won't start...flooded I think....my last 65 degree day for the duration, crap....I jumped it with a car battery and it just wouldn't go...this bike has started great up till now....I did check a plug, clean, no prob...I did clean the carbs when I got it 8 mths ago....maybe tomorrow I can find some time to fool with it...spray some wd40..but I'm thinking flooding out equals another carb cleaning...
Guest
Posts: n/a
Without more detail its hard to say ... but as Sprockie said ...if you kicked the side stand up and she stoped ....the switch is possessed .. swap it out ..
but if it is not the side stand switch ...and she is stopping as soon as you lift her straight up ... then I would guess your float levels are a touch high , OR you have a needle and seat that is leaking a bit ...
Did you ever modify the float levels ??
Have you EVER? replaced the needles and seats in the carbs ?
