winter gloves
RE: winter gloves
Shadow, R1000 asked winter riders to comment. Seeing as its 40 flipping degrees where you are.......
I use GERBING heated gloves, after having the same problem with heated grips and wasting money on inner gloves (Hi Pete). Honestly, there is no going back once you have felt the warmth. They are waterproof and not to thick. Don't get an oversized pair as they give quite a light and can be loose if you buy too big a size. They are well worth the money IMHO.
Flogging Fhil
Flogging Fhil
RE: winter gloves
Just because I live in a sub-tropical area NOW, Flogger, doesn't mean I've never ridden in cold weather[:@] And I never used heated gloves in the UK- England wasn't cold enough !!......and I thought all you Peelers were tough ?he he
And now we know why your battery's always flat - heated kit !!
Don't forget, inland in South Africa it's 5500 ft above sea level, and temps around Johannesburg in winter get down to -10C. There's no snow,and the roads are dry because it rains in summer, so you can ride......and we did. Madness......
RE: winter gloves
ORIGINAL: Shadow1
You could try the Oxford thermal glove liners - I am told they are very good......
I've now ordered a pair of Rukka gloves which I believe should be fine in combination with inner gloveshttp://www.rukka.com/lfashion/rukka/...p;Expand=1.6.4
Thecombo may be a bit bulky, but I want tobe able to ride even when it is very cold and thismay fix it.
RE: winter gloves
This winter I've been using Jofama Tour de Force which are ok a few degrees below zero.
I believe the most important body parts to keep warm are the torso, neck and head. Then, as long as your circulation are ok, you shouldn't freeze too much. I know opinions often differ in this matter.
In cold weather personally I am more concerned with losing grip on slippery surfaces as the tyres gets hard and inflexible.
Edit: forgot the link
RE: winter gloves
I guess the circulation is not what it should be due to previous smoking and abuse of hands when it has been cold. Thecurrent snuff consumptiondoesn’t help a lot either. You are right about keeping the head, torso and neck warm, I do but it doesn't seem to help my hands. I have noticed that the hands become warm very quick when the pace goes up (not necessarily the speed), this is probably a good sign of reduced circulation that is overcome when the hart pumps more and the hands are more active.
Edit, snuff linky http://www.swedish-snus.com/
