What's your best parking lot hack job?
We've all been there: having a good ride, then something goes horribly wrong. The bike dies, the swingarm falls off, the battery explodes.....and there's a Sears/WalMart/Autozone/generic auto store right ahead (as if the bike knew)
What is the best job you've had to repair / replace in the middle of the parking lot?
Me? Had to repair the plastic 3-way junction for the cooling system in a Walmart parking lot. Found some QuikSteel in the auto section (never leave home without now) and sealed all three hoses to the junction block. That was after riding along I-81 in the breakdown lane in Virginia for 2 miles with no coolant (no thanks to All-State motor club who couldn't find anybody to give me a tow)
Then today, I'm cruising along, going to a bookstore to get a magazine when I notice my shifter feeling sloppy. I stop, look down and see that the shifter is almost pointing at the ground. Panicking, I look around and spot Sears right there. I pull in, assess the damage (pivot bolt backed out, damaged end of bolt threads, then I damaged the bolt hole by trying to force it back in), go into Sears and buy a Bolt Rethread kit (which I already have @ home) and spent the next 45 minutes carefully fixing the bolt and hole (thank god for my expanded tool kit that I bring everywhere)
I was riding to work one day when all of a sudden my clutch lever pivot bolt decided it wanted to pop out. So i had to hold the lever so i didnt lose it, pull over and let the bike slow down till it stalled to a stop. Got off the bike and looked on the side of the highway only to find some bailing wire. So i put the clutch handle back in place and wrapped the wire through the bolt. And it worked quite well till i bought a replacement.
Clutch cable broke at the lever, wrapped a screw-driver around end of cable and pulled
HARD to clutch out of first, spped-shift from there.
Had to change the rear U-joint on a 65 Barracuda on the side of the road in the rain once. (If we get to include car stories) or, same car, pulling over in a foot of wet
snow to shake the linkages free of all the packed-up snow binding them.
Ern
Ern
Not much with the bikes. I've replaced fuel lines, removed a petcock, changed tire, etc. All dumb easy stuff.
On cars... hell, I've done it all. lol..
I replaced a timing belt on a Honda accord in a wendy's parking lot (one tooth off so I had to finish the job 50yrds down the road in a quick fill lot..haha). Water pump on a corsica in someones driveway. Alternator and belts on a jeep cherokee alongside the road. Radiator on another jeep in the parking lot at work.
Axle, tie rod, rim, etc in someones front yard (don't ask... LOL)
All good times.
All good times.
i replaced a throw out bearing on a nissan hardbody in a court house parking lot. Put a tire back on a motorcyle that fell off on a customer in a sonic parking lot. Swapped a motor in a 87 toyota pickup truck in a walmart parking lot.(motor blew so drove my buddies picker truck to his house and loaded up the spare motor he had and swapped it in the parking lot.) A lot of fun stories
OH EM GEE and WOW! lol quite a few crazy stories! and I have NONE! had to change a flat tire in a lowe's parking lot on my camaro. ran over a HUGE bolt. I don't even know how it got in my tire but the hole was about the size of my pinky after it flew out! I was going to try to drive it to a shop i take my car until about a 100 yards later the stupid bolt flew out!
On a previous bike I had replaced the rear tire and somehow got the rear disc pad out of place. Since I don't use the rear brake much I didn't notice until I got to work. I was able to remove the rear wheel and repair the brake using the factory tool kit!
